When an old revision of a product is being installed where a newer revision is already installed, I have found the following to be true:
* Executable (EXE) files are not replaced (with older version).
* Other files are replaced.
I have worked around this by deleting the EXE files prior to Apply Install using Call DLL (DeleteFileA). I attempted several more obvious solutions (e.g., Install Files Copy Option, Delete Files On Installation, Uninstall prior to Install) but none worked.
I don't think this is an uncommon scenario (downgrade). I also don't think it is a hard problem. So I am posting here because I suspect my workaround is non-optimal. What is the optimal way to do this?
I imagine uninstall-before-install makes the most sense - and if that is the recommended solution, I am unsure how to construct the script so that the uninstall occurs properly prior to install.
Thanks in advance for any thoughts.
Replace New Executable With Old Executable
Actually, all default InstallAware scripts have auto-uninstall before installing the current version (be it old or new versions) by default. If you removed this behavior from your script, you may want to compare with a default script.
Transform Installs Too?
I compared my script to the default generated and Process (Un)Installation region looks the same. Namely REMOVE controls whether Apply Uninstall gets hit. So, if I read between the lines - REMOVE will be true as long as a new revision code is used. Is this correct?
The behavior I am seeing is that the old EXEs are still in TARGETDIR. I assume Uninstall is not occurring, but I have not verified that.
Now, does Transform Install change the picture? I am making use of that in my script.
Thanks again for your thoughts.
