Lingering \"License\" message
During my install (using Swoosh theme), when you clck next on the Licensing page, the page clears and the word "License" lingers there while the next page (Destination Folder) is being setup. This looks sloppy. Is there something i can do to fix it?
How old is the test hardware?
I see, so it has little to do (if anything) with system draw speed.
The workaround is simple - load your license agreement directly into the license dialog: Open the licensecheck dialog in the dialog editor, select the license box, choose the Lines property in the Object Properties window, click the "..." button, and paste your agreement in there directly. Then double-click the license box, switch to the Object Behavior tab, and set the "Receives Information" field to none.
An even simpler workaround is also available - instead of hosting a tree control that displays folders, you may host a text field and a browse button instead. This will eliminate the load delay and hence the flicker effect. For a theme that does this, look at the Plain dialogs.
Hope these suggestions help alleviate the problem!
Users browsing this forum: No registered users and 69 guests
