Problem with the presentation of a dialog under XP
Post complete new themes or wizard dialogs here.
jasper
Post by jasper »
I have build a setup for our software and when I install it under vista everything works fine in the presentation of the dialogs but under xp the progress-dialog of the installation of the pre-requisites has a fault.
I attachted two picture of the same Dialog under different OS. I marked the fault red.
What can I do to solve the problem?
Thank you in advance.
jasper
Post by jasper »
I solved the problem by installing InstallAware on Windows XP and editing the dialog in this environment.
