reformulating my question about APPDATAFOLDER
benjoTLV
Post by benjoTLV »
Sorry but I don't understand your answer.
In Installaware you have the ability to define in your installer in which folder your application will be installed without popinp any "custom dialog"
You just put a variable in the Targetdir field in the run program installaware dialog.
There are several choices of variables like $PROGRAMFILES$ or $MYAPPDATA$...
My question is very straightforward I think: What is the variable name to make the installer install my application in "ApplicationData/Local" folder on Vista?
benjoTLV
Post by benjoTLV »
Sorry, this should not be a new post but a reply in my previous post
