Advanced Shortcut options
tillot
Post by tillot »
We have an install with several different shortcuts. I can't figure out how to do the following:
  • Have shortcuts with different UAC invoker levels (This only appears to be able to be set at the install project level)
  • Have some of the shortcuts require they are run as an administrator.
  • Have some of the shortcuts run with XP compatibility mode settings. (I can't find where to specify XP compatibility mode)
Shortcut compatibility options available in Vista that I can't find out how to set:
