Dear Support,
I try to repalce the gray.avi file from the theme titantium with one of my self.
If I try to change the avifilename an error occurs "Invalid poperty value". Otherwise if I change the name back to gray.avi its works and shows me the avi.
So I think the proplem is maybe the avi file format.
So please give me an description how I can create an avi which is working with your animate control. It would be also nice to know which tools do you use to create on. In the attchment
you can find my avi. It would be also nice if you check/modify my avi file.
Thanks in advanced
Christian
