"create folder" is not always work !!
Welliam
Post by Welliam »
I used "create folder" in the following script and it does not work, it work only when I move the line to the top of the script !!
apply install ...
run program ...
create folder c:\new
all lines run normally except for the create folder , but it work when I move it to the top !
why this happen ?
(I tried to make copy and paste here but alot of text generated !)
Welliam
Re: "create folder" is not always work !!
Post by Welliam »
any replay ??
You have already discovered the cause; you want to read "Setup Commands Preceding Apply Uninstall" topic in the help file for a full discussion.
Welliam
Post by Welliam »
ok thanks !
