In the license agreement dialog I want to put a compiler variable in a label caption like, "Licensee: #LICENSEE#"
I build the project in the command line with miabuild.exe and put LICENSEE=aCompany in the end of the string but the caption is not replaced with "aCompany". While compiling I can see that miabuild.exe has recognize the parameter so that's not the case.
Should it be possible to do this? If not, is it anohter way to send a parameter to fill a label caption with information?
Thanks in advance.
/Niclas
Compiler variable in a dialog
Hi Niclas
Compiler variables are substituted in the script and project options dialog only. If you want your dialogs to also substitute, in your script first assign a variable to the compiler variable value, and then use that variable in the dialogs.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 14 guests
