I would like to change which signature is used based on the OEM build I am performing.
So I added compiler variables for the signature public key, certificate, URL and password configuration in the Authenticode signature properties.
This doesn't seem to work.
I tried hardcoding the Password (it's understandable if this wouldn't accept the compiler variable), but still no luck.
Is this a limitation of IA or am I doing something wrong?
For example I have set the certificate file to "#SIGNATUREPRIVATEKEYFILE#", and am defining that with the miabuild command line as such:
miabuild "c:\development\buildtemp\Installer\installer.mpr" /o="c:\development\buildtemp\installer\output" /b=1 "SIGNATUREPRIVATEKEYFILE=\\server\share\certificate files\private keyfile.pvk"
