Is it possible to install a file with a different name? I have an installer that is used to create three different versions of the same app. Basically, the full app and two levels of demo. I'm using conditional compilation to set the appropriate Install files line, but I would rather have the main exe called the same on the destination PC. So on my development PC, I have MyApp.exe, MyAppDemo1.exe and MyAppDemo2.exe, and I want whichever is selected in the conditional compile to end up as MyApp.exe on the target.
Is this possible at all? I tried setting the name of the file, but then discovered that's the path, not the filename! I can hack this by renaming them all in FinalBuilder, but I'd rather do it in InstallAware if possible.
Thoughts?
Matthew
Installing file with different name
Users browsing this forum: No registered users and 69 guests
