Starting a .NET service
sdolan
Post by sdolan »
Hi, my installer needs to install a couple of .NET services.
I've successfully got it to do this by following the steps:
Install Files... to copy over the necessary files
Apply Install...
Run .NET Installer Class... to install the service.
This is all good. I run into a problem though when I want to _start_ the service. I can't use 'Control Service' because I believe I would have to put the command before the 'Apply Install' command and at this point in the script, the service does not exist, so the command fails.
How can I start my .Net services?
Re: Starting a .NET service
That's a good question. You can do it by adding a second Apply Install after the Control Service command.
sdolan
Post by sdolan »
Thanks Michael - I'll give that a go.
