build error
mazzaror
build error
Post by mazzaror »
Hy I downloaded a demo version and I'm trying to create an exe single file from a project.
Installaware create the setup exe file only the first time , the second time I try to recreate the seup exe file after some time I see the error below ! ERROR DURING BUILD....
I try to understand the problem and the issue is that t file MSVCRT20,DLL inside the OFFLINE folder in LOCKED ! I mean I cant delete it from window seems locked also If I close installaware ! I cant delete the file anymore also if I restart win xp in safe mode !
Anyone has any idea ! Now I have a folder in mi pc that cannot be delete ! The OFFLINE folder ! And I cannot recreate again the setup file cause to this problem.
Copied file C:\PROGRAMMI\FILE COMUNI\SYSTEM\OLE DB\oledb32r.dll
Copied file C:\PROGRAMMI\FILE COMUNI\SYSTEM\OLE DB\OLEDB32X.DLL
Copied file c:\windows\system32\VB40032.DLL
Copied file c:\windows\system32\VEN2232.OLB
Copied file c:\windows\system32\msvcrt20.dll
Error during build: Unable to copy file to C:\Documents and Settings\rudi\Desktop\SETUP_GIC\2\Release\Single\data\OFFLINE\4E5D4B9D\431AE4FA\msvcrt40.dll
Thks :oops: :oops: :oops:
