Hello
When uninstalling an application, Installaware does not remove all files in the application folder.
I think this happens because my application has an update system. So when an update occurs, the files are (almost of them) different.
What can I do to enforce all files in the application folder are removed?
Thank you in advance.
Tiago
Uninstall all files in folder
sdeschenes
Re: Uninstall all files in folder
Use the command Delete Files Recursive. Make sure to include "\*" when you pass the directory. For example: $TARGETDIR$\*
It worked!
Thanks!
Thanks!
