Problem upgrading to 9R2
benjoTLV
Post by benjoTLV »
I installed the 9R2 version and reinstall all the plugins I had in version 9 but still, when I try to compile my installer I get an error message:
"some plug-in are not available on your system" etc... and then the project closes.
After some testing, I noticed that this message appears when I select .NET3.0 as a prerequisite. This message does not appear when I select only 2.0
Also, I still get the splash screen of version 9, not version 9R2. Is it ok?
Bottom line, I cannot run my previous projects and I cannot even recreate them from scratch...
Any ideas?
Re: Problem upgrading to 9R2
Just install the needed runtimes. Also, your license must be the same version as the trial version. You are currently out of sync.
benjoTLV
Post by benjoTLV »
Thanks Michael!
I started already a "repair" and it is a pretty long process but as soon as it finishes, I will try what you suggested.
Thank you
benjoTLV
Post by benjoTLV »
OK. Splash screen is solved by following your advices but I still have the missing plug in problem... is there any plug in that are used by the automatic script of IA for pre-requisite that are not in the package and I need to download separately?
benjoTLV
Post by benjoTLV »
Cool! working now.
Thanks a lot
