Edit ini Line->Remove not working
5aclockshadow
Post by 5aclockshadow »
Can anyone tell me why?
Text:
Edit INI File $TARGETDIR$\Visitor Watch Reports\Reports.ini, [Report33] NumberOfFields=
Code:
~InstallAware Clipboard Data~
~Edit INI File~
~{023454EC-71A1-49C7-97CD-21BDE39EBE0A}~
~$TARGETDIR$\Visitor Watch Reports~
~Reports.ini~
~2~
~Report33~
~NumberOfFields~
5aclockshadow
Re: Edit ini Line->Remove not working
Little more info:
My understanding is that setting Edit ini action to Line->Remove should actually delete the line...so when set to NumberOfFields (I also tried NumberOfFields=2) it should remove/delete the line.
So from this:
[Report33]
ButtonName=<empty>
NumberOfFields=2
FieldName0=Start Date:
FieldType0=Date
FieldName1=End Date:
FieldType1=Date
ReportName=rptByDateRangePhoto.lst
To this:
[Report33]
ButtonName=<empty>
FieldType0=Date
FieldType1=Date
Is this correct or am I missing something???
Are you actually testing for the deletion after Apply Install executes?
5aclockshadow
Not sure what you mean...all the code is above/before the Apply Install.
I run the setup on a test PC and when I open the ini file the line is still there.
I can get Line->Create or Update to work just fine...if I run the code below it changes "NumberOfFields=2" to "NumberOfFields=". But how can I get the "NumberOfFields" line to be removed/deleted?
Text:
Code:
~Edit INI File~
~Reports.ini~
~0~
~Report33~
~NumberOfFields~
Thanks for the help.
What I am asking is - is the removal not happening even after Apply Install has been called?
5aclockshadow
Correct, the removal is not happening even after Apply Install has been called.
Is there some other way to test this by stepping through the code?
Thanks again.
That's odd. Can you send us a reproducing test project that doesn't reference any other files on your system but just illustrates this alleged bug? I will try to reproduce and escalate to R&D for resolution, or if it is some kind of user error, get back to you with a solution.
5aclockshadow
Michael Nesmith wrote:
"I see the problem. You are installing and editing the INI file at the same time, this is what is causing the confusion. I would manually copy the INI file using Call DLL Function on kernel32.dll's CopyFileA and then process the INI edits."
5aclockshadow wrote:
"Ok, thank you I will try that.
One question though, how come the 'Line->Create or Update' action works?"
"Because lines are deleted first, then files are copied, and then lines are updated. So that one will work."
"I think I got it working so thanks for all the help!
However, I do have 2 quick questions:
1.) Now the uninstall doesn't uninstall the copied file (and therefore $TARGETDIR$ doesn't get uninstalled). Any suggestions?
2.) I don't understand this statement: "Because lines are deleted first, then files are copied, and then lines are updated."
Based on this comment I tried to run the edit ini statement that deletes lines first using $SUPPORTDIR$ for the location. I did this before 'Apply Install'.
Second, I copied the file after 'Apply Install' (from $SUPPORTDIR$ to $TARGETDIR$).
Third, I ran the edit ini statement that updates lines using $TARGETDIR$ for the location.
My results were that the update statement didn't work. Once I moved the update statement "up above the 'Apply Install' w/ the delete statement" then it did work.
So is the order:
1. lines are deleted & updated
2. files are copied
If so, then how come the update worked in my original setup w/o CopyFileA?"
"Apply Install redoes the entire install cycle including commands from the previous cycle, so files may get overwritten and entries re-written.
I'd Edit the INI file directly from $SUPPORTDIR$ and after Apply Install copy it over to the destination.
You can add a Delete Files statement before your Apply Install (not Apply Uninstall, read the help file topic "setup commands preceding Apply Uninstall" for a related discussion) with the "delete on uninstall" flag to remove the file explicitly at uninstall time,
Thanks..."
"Sounds great. Again thanks for all the help!"
