Reference the help topic "Source Resolution from the command Line".
I am trying to add the following: <setup.exe> /p=<original setup sources>\data
I usually do not use the MSI Code editor and I cannot figure out how to insert this.
Also I assume it goes just before the existing Apply Patch but the help does not state this.
Software Rev: Installaware 7 R2
Thank you
Patch Source Resolution
Re: Patch Source Resolution
Actually, this doesn't have anything to do with the MSIcode script, its how you start the patch setup.exe file from the command line (you are pointing it to the cached location).
