(Un)Install MSI Setup does not remove completely
gweihs
Post by gweihs »
I am calling a setup (AI) from wihin another setup using the "(Un)Install MSI Setup" in order to uninstall a product. It does seem to uninstall the product, but the Add/Remove Programs still contains an entry for the product. When I click on that entry to manually uninstall it, it says that an error has occurred and the product may have been uninstalled already (which it was).
Why is Add/Remove Programs not being refreshed? Is there anything i can do?
This is as designed - you can just delete the key using the Delete Registry command after the uninstall.
gweihs
Post by gweihs »
Delete what key?
The registry key for your program that lists it in Add-Remove Programs. This key is not removed automatically on uninstalls using the plug-in.
gweihs
Post by gweihs »
Am I missing something? Specifically, what key are you referring to. I created no key (explicitly) when i created the setup. Specifically, what key?
Ah, I assumed you already knew where ARP keys were stored at. Sorry about that. Here goes:
SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Uninstall\\$TITLE$
The hive will be HKLM or HKCU depending on an All Users or Just Me install.
Note that the $TITLE$ needs to be the title of the uninstalled product. If your title has changed between versions, you need to use the old title.
johnchapman
Re:
Post by johnchapman »
MichaelNesmith wrote:This is as designed - you can just delete the key using the Delete Registry command after the uninstall.
Where is this described as "as designed"? It seems odd to me that installaware would automatically populate the registry upon installation, but not remove them upon uninstallation?
Re: (Un)Install MSI Setup does not remove completely
Dear John,
in-fact, it is exactly in this way... if you found a different behavior, there is probably something wrong with your project.
