I add ODBC driver to my project, run the setup will get the error message: "Windows Installer cannot update the system file "c:\windows\system32\odbcjt32.dll".
How to fix it?
Thanx.
Cannot update the system file !
Re: Cannot update the system file !
That can only be installed by the operating system itself or service packs. You should not attempt to install that file in your own setup routine.
