Disable installation into certain folder
tosch
Post by tosch »
When the user selects an installation directory I want to check if a certain program exists in the selected folder.
If this is true I want to force the user to select a different directory. I'm doing this because I don't want two of our application to be installed in the same directory for various reasons.
Can anyone give me some directions on how to solve this? Can I run a script when a button is clicken and then enable/disable a control on a dialog?
Thomas
sdeschenes
Re: Disable installation into certain folder
Post by sdeschenes »
When the user selects their destination, use the Does File/Folder Exists command on $TARGETDIR$\appname.exe. If the app exists in the target directory, display a message telling the user to select a new directory and after the user dismisses the message, reload the destination dialog.
tosch
Post by tosch »
I was looking for a way to add script lines to controls on the dialog. But checking this after returning from the dialog and then redisplaying the dialog works fine. Thanks.
Thomas
