Read from Text File buggy on CN Systems
one customer gets an error message (Runtime error in script - RichEdit line insertion error), see attached image. At the named line I only have an "end" statement (closing an if statement).
Error message attached .
Has anybody a hint what could be the reason for the error message?
Thank you,
Alibaba
Thank you,
Alibaba
- Screenshot Error Message
- runtimeError.png (44.86 KiB) Viewed 8577 times
Re: Runtime error in setup script
I get this error on chinese systems only. Has InstallAware any restriction for chinese systems?
I now removed the RichEdit Control from license dialog and now I get the following error (see attachment).
This error message comes right after I selected english from the language selection, but not if I select german.
- Screenshot after removing RichEdit from dialog.
- ia-error.png (13.96 KiB) Viewed 8567 times
A minimum reproducing project will help R&D track the issue down and develop a fix, we'll test it for you exclusively on Chinese systems.
OK I will try to make a new project where you can reproduce this.
Ok seems that I found a workaround in using two different Memo Box dialogs, depending on language (german, other) and then reassign translations. If you want I can sent you my original project.
You simply has to make a Dialog with a RichEdit field and then fill the field by reading from a text file using ReadFromTextFile Function.
Run this on a chinese system and you get the error message from first post.
I made a sample project, where can I send/email it to?
Read from Text File #READALL\$SUPPORTDIR$\license.English.txt into Variable LICENSETEXT
Please send it to support at our domain name dot com. Thanks for taking the time!
Any news on this
I still have the problem with IA10 generated setups. They always stuck if they were run on special chinese systems. I had attached a nfo file of two relevant computers. Please try to fix this problem, otherwise I will always have problems with this computers and have to try to find workarounds...
THX
THX
- two_cn_computers.zip
- (130.53 KiB) Downloaded 378 times
Re: Read from Text File buggy on CN Systems
Does this happen on a traditional or non-traditional Chinese system?
I had attached the system informations in last thread. But I also asked customer now. He told me that they use Windows XP English version. In .nfo file you can also see that locale is set to "People's Republic of china". I will try to reproduce it here. Is there a known problem with read from text file function. May be this is related to non unicode support of this function?
Dear alibaba,
Theoretically, Read from Text File does not support Unicode.
Yes I will try to make a small project, but in fact I already sent an email on June 07, 2010 to your support team and never get an answer than "Thank you". So maybe it is enough to look in your database and search this email. The problem still occurs in IA10.
So I am tired of sending again a project with the same problem reported a half year ago.
