Uninstalling causes the install to check for prereqs.
Roostar2004
I was wondering if there was a way for the installer during the uninstall process not to check for the prereqs. Currently if a user uninstalls a prereq such as runtime for crystal reports before uninstalling the entire application they must reinstall those prereqs before continueing.
Re: Uninstalling causes the install to check for prereqs.
Of course, just wrap the prereq block inside an If...End clause testing whether MAINTENANCE is TRUE or not.
