Silent uninstallation problem
lukasz
Post by lukasz »
I'm trying to work out how to perform a silent uninstallation from the command line. This doesn't do the job:
ourinstaller.exe /s MODIFY=false REMOVE=true
If I remove the /s flag the dialog pops up with the correct option (uninstall) selected. But when running in silent mode nothing happens. Am I missing something?
Also, is there any reference available for all command-line options?
Re: Silent uninstallation problem
Try to debug this inside the IDE by setting the $SILENT$ pre-defined variable to TRUE and seeing what goes on when stepping through setup.
