Problems with Transparent Text
Gareth Owen
Postby Gareth Owen » Mon Jan 30, 2006 8:20 am
Transparent text does not seem to work on Windows 2000 :cry:
We have just finished setting up a nice corporate theme for our installers and are in the final stages of testing.
And some testers commented that the text had a block background.
After much testing it would seem that this is due to the installer being run on Windows 2000.
Is this correct.
I have a feeling that OS supported transparent text was only introduced in Windows XP.
Is this correct, as I cannot see any information in the Help about this sort of limitation. :?
Gareth Owen
Postby Gareth Owen » Mon Jan 30, 2006 8:34 am
Hmmmm, further investigation showed that this does actually occur on WinXP when you have it set to "Classic Windows Theme".
Any Ideas?
Do we have any information on when the transparency does and does not work?
Gareth Owen
Postby Gareth Owen » Mon Jan 30, 2006 8:51 am
Ahhhhhh!! :cry:
Well so much for my previous testing, Please ignore my observations.
So far I have had this issue of blocked out text.
On 1 computer running Windows 2000.
One computer running Windows XP in "Windows Classic" style
Any ideas?
Postby MichaelNesmith » Mon Jan 30, 2006 10:25 am
Hi Gareth
From my own experience with theme building, these problems are generally solved when the Transparent property of the labels are set to false and then back to true.
If you take a look at the pre-built InstallAware themes they work correctly with transparencies on all operating systems - not requiring Windows XP.
So, you can set Transparent to false and then back to true, or you can copy-paste the labels in the pre-built themes which already have working transparencies.
Gareth Owen
Postby Gareth Owen » Mon Jan 30, 2006 10:30 am
Ok, that worked. :)
Postby MichaelNesmith » Mon Jan 30, 2006 10:41 am
Glad to hear it! Always be sure to test your dialogs on a variety of operating systems, screen resolutions, and font sizes.
Users browsing this forum: No registered users and 126 guests
