Case install
Case install
I am in the process of developing an installer with Installaware Studio 9 R2. What needs to happen is if IIS is installed the just setup a virtual directory and install the application. If IIS is not installed give them the option to install the application with an embedded IIS server. I am able to develop each as there own installer but I would like to only have one installer to do both types of install. If possible could someone post a sample that would allow me to do this or point me in the right direction?
Re: Case install
Good question. Just check whether IIS is installed in the script using Get System Settings and then wrap the IIS related parts of your install actions around an If...End clause testing for the value of the variable populated by the Get System Settings command.
