I downloaded and installed the trial version of the Studio platform of InstallAware. I used the hoplite.exe tool to convert a Wise script file generated with Wise Installation System 9 (WSE) to an MIA file. When I attempt to load the converted script I receive the following error (in a message box):
untitled - InstallAware Studio
'SWITCH_TWO' is not a valid integer value.
OK
I am totally baffled as to what this means!! The 'SWITCH_TWO' was a variable in my orginal Wise script. Any help is appreciated.
Kevin
Not a valid integer value - what is this?
Re: Not a valid integer value - what is this?
This appears to be a bug with the conversion tool.
Would you mind sending us your scripts, so we may take a look at the issue and fix it? Thank you.
Please feel free to send us any additional scripts that might also be failing.
We'll get them all fixed for you.
I have attached a ZIP file containing the original WSE file and the converted MIA file. Before I continue to convert WSE files, I ask that you determine what the problem is with the one I sent. It might be that I have to make changes to the WSE file before I actually convert it. Thanks for your support.
- Convert2Mia.zip
- (137.72 KiB) Downloaded 13549 times
Thank you!
Can you tell the status of fixing the conversion tool??
It has been escalated to R&D. We will post here when we hear back from them.
Would you try with the attached version, and report whether it fixes the issue or not.
Thank you.-
Thank you.-
- Hoplite Test.zip
- (63.79 KiB) Downloaded 4781 times
Tried the new convert program with the same WSE file as before. The following is the error message returned:
Error
Hoplite port failed
OK
Error
Hoplite port failed
OK
Hoplite.exe has been deprecated long ago, and is no longer shipped with IA since its functionality is now provided by HopNext. You are not supposed to run these tools manually either. Replace the current HopNext.dll with the one attached, and test it by creating a new Converter Project using 'Convert Wise Setup'.
Thank you.-
Thank you.-
- HopNext.zip
- (103.82 KiB) Downloaded 18298 times
