Copy/Move Local Files
xqOliver
Post by xqOliver »
Hi
I used the lastest version which is InstallAware 9 R2.
I can not using Move Local File or Copy local File.
Even I tried using previous posts example Call Dll Function (Kernel32.dll) still does not working.
~InstallAware Clipboard Data~
~Call DLL Function~
~{B8C9831B-A927-4B0B-9D46-6DF15C50AA71}~
~Kernel32.dll,CopyFileA,bool,,"pointer to string","$SHORTCUTFILESALL$\Test\\*.*","pointer to string",$SHORTCUTFILESALL$\$STARTMENU$\\Backup\\*.*,bool,0,$~
~mIDEFunc.dll\mEXEFunc.dll~
Can you give an example?
Re: Copy/Move Local Files
Unfortunately this WinAPI does not accept wildcards.
