Readonly folder
pokr
Readonly folder
Post by pokr »
I'm having a problem where a folder I create at runtime gets the 'Readonly' flag set, so any attemps by the user to create a new file on that folder fails.
Permissions on the folder seems ok, it's just the readonly flag.
Thanks, regards,
Octavio
Re: Readonly folder
Post by mills »
Let us know if this post doesn't get you going in the right direction:
http://www.installaware.com/forum/viewt ... 11&start=0
Remember if you resort to using CreateDirectoryA before Install for a folder you'll want removed during uninstall, you'll need to provide a call to RemoveDirectoryA for the same folder(s) right after uninstall.
