Target Folder Is Being Ignored
Rob Cole
Post by Rob Cole »
Using InstallAware-Express - Seems no matter what I put for 'Target Folder' it always defaults to "Program Files...".
I am trying to install a Lightroom plugin which needs to be put in "users-app-data"/Adobe/Lightroom/Modules but I haven't been able to figure out a way to do it yet.
Any ideas? - Please help - project deadline is upon me...
Rob
Re: Target Folder Is Being Ignored
Post by mills »
You can set the Target Folder in the Design GUI under Application Information->Project Properties. You'll see it's set to "$PROGRAMFILES$\$TITLE$" by default.
Additionally, if you are to set the value of TARGETDIR in MSIcode, make sure to comment or delete the line that sets it to the "default". It can be found in the "Setup User Interview" region. It was on line 80 of a new basic setup. (Just search (ctrl+F) for TARGETDIR in MSIcode to find it the easiest).
