How do I launch an informational dialog
EpicorRelease
Post by EpicorRelease »
I am probably missing something obvious being a newbie with Install Aware 9 R2.
I have a prerequisites dialog that displays all necessary components and whether the target computer has said components installed.
If the prerequisite is not met, then a button labeled Details is enabled and visible. Is there a way to have the new Details button launch an informational dialog or message box and then return back to the prerequisite dialog?
Thanks!
Re: How do I launch an informational dialog
Post by mills »
Setting a button's action to Return from Dialog will cause the button's name to be the return value from a dialog/form.
You'll want to use labels and goto statements.
I'm including a sample project for you to examine, which behaves as you describe.
Also, examining the script that is generated when you create a Basic Setup is a good way to familiarize yourself with MSIcode basics.
Info.7z
(2.34 KiB) Downloaded 346 times
EpicorRelease
Thanks for the sample script. It totally did what I needed.
