Installaware r2/sp3 doesn't minimize to taskbar
dunion
Post by dunion »
I was using it on monitor 2/ extended desktop . From then on minimize doesn't work on Vista x64.
Click on minimize button, nothing happens, same with clicking on it in the taskbar.
dunion
Re: Installaware r2/sp3 doesn't minimize to taskbar
Post by dunion »
Closed IA9 R2, restarted, minimize problem went away.
Built install run get 'Access violation at address 73c49f5b in module "Richedit20.dll". Read of address 0000005F.
Anything familiar?
dunion
Post by dunion »
May have been an artifact of the update from SP1 to SP3 of R2: I went to the license form, opened it in the designer, saved it again (it has the richedit control), and rebuilt and made the problem go away.
Post by mills »
Thank you for posting your resolution!
