I use Installaware 9R2.
Does anyone know how to set the version of the setup.exe created ?
It seems to be independent from the product version of the application to be installed which can be entered in the project options.
Thank you in advance !
Ali
Version of SETUP created
Re: Version of SETUP created
If I understand correctly, you will have to consult the vendor for the compiler you use.
In Visual Studio, I think you'd want to look in the project properties->Assembly Information.
AlejandroNehring
Thank you for your fast answer!
Oh sorry, I made mistake.
If i specify a program version in the Project settings, it is taken over for the setup.exe.
By mistake I noticed a different behaviour.
Now the problem is solved.
Ali
Ali
