kernel32.dll
bendrouet
kernel32.dll
Postby bendrouet » Fri Feb 03, 2006 10:27 am
I wrote a very simple installation containing just one file.
I use vmware to test the results of the installation on different OS.
The final exe is build with compression mode at best and a single SFX file is generated.
On my development computer, the installation works fine (Windows XP).
But when I try to install it on a Windows 95 vmware image, I have this message :
"The file Test.exe is linked to a missing exportation of KERNELL32:SetProcessAffinityMask"
And a new error windows appears
(InstallAware initialization error)
"a device linked to the system does not work properly"
I did not made any restrictions on the client OS with the wizard. So it should install on any Windows OS.
Can someone help me to resolve this problem ?
thank you
Postby MichaelNesmith » Fri Feb 03, 2006 11:36 am
This issue has been reported - a fix will be available shortly (Monday).
bendrouet
Postby bendrouet » Mon Feb 06, 2006 5:00 am
Thank you for the fix
I have just a simple question
Where can I download the fix patches ?
Are they available for trial versions of IA ?
Postby MichaelNesmith » Mon Feb 06, 2006 1:57 pm
The new versions will be posted live later today.
Users browsing this forum: No registered users and 41 guests
