Product Name in Properties dialog
agale
Post by agale »
Hi
The exe installer generated does not have the product name and product version filled and I cannot find a way how to insert them from within the installer. Attaching is an image of the properties dialog. This can be opened by right clicking on the exe installer and select properties. Is there a way to insert these?
HAHNmediaservice
Re: Product Name in Properties dialog
Post by HAHNmediaservice »
We have to agree to that, see here:
Furtermore our setup is build in language german; the details tab shows up "Englisch (USA)" which is wrong.
Help expected soon!
HAHN mediaservice
Inh. Irena Hahn
Seif-Wald-Ring 26
54329 Konz-Roscheid
Tel: +49 6501 6 03 96 79
Fax: +49 6501 9 22 31 29
Post by mills »
I've added this to our feature requests:
Product name should appear in installer exe properties/details.
HAHN, what is the default language you have selected? German?
In the mean time, you will need to use a resource editor. See this for ideas:
http://www.governmentsecurity.org/forum ... opic=18905
HAHNmediaservice
Yes, operating system's language is German, default select language in our setup is German too respectively we're only using German language in our setup (no language selection dialog).
HAHN mediaservice
Inh. Irena Hahn
Seif-Wald-Ring 26
54329 Konz-Roscheid
HAHNmediaservice
What about this post? Do we get an answer on that issue?
HAHN mediaservice
Inh. Irena Hahn
Seif-Wald-Ring 26
54329 Konz-Roscheid
Post by mills »
The answer has already been given earlier in this post.
Please, fellow posters, while I may tolerate you asking questions that have been answered in another post, there is no reason for you to ask for answers that can be found within the same post.
Also, if you have not asked a question which requires a follow-up answer, you should not be expecting a response.
norbertjurkiewicz
Post by norbertjurkiewicz »
Has this feature been implemented as of IA2012? These two fields are still blank.
GnomeMN
Post by GnomeMN »
Our team is also interested in being able to update the ProductVersion field. I know it was mentioned in this topic that there was a feature request for this functionality. Have there been any updates to this request or is it being considered for an upcoming release?
Thank you for your time,
Paul
Dear Paul,
I'm really really sorry but actually it is not.
I have personally added the request to our TO-DO list. ( ... it should be already there ... but there isn't).
