Call functions in custom DLL-Library
HAHNmediaservice
Post by HAHNmediaservice »
We are going to write an DLL-Library with functions we need during our setup. Is it possible to use those functions even if the DLL is not yet installed / the setup is not finished?
HAHN mediaservice
Inh. Irena Hahn
Seif-Wald-Ring 26
54329 Konz-Roscheid
Tel: +49 6501 6 03 96 79
Fax: +49 6501 9 22 31 29
alibaba
Re: Call functions in custom DLL-Library
Post by alibaba »
Yes if you use it as Support file (add it to Creatives). Path to the file is then $SUPPORTDIR$<your dll>. So you don't even has to install the dll.
HAHNmediaservice
Tahnk you, it work's.
HAHN mediaservice
Inh. Irena Hahn
Seif-Wald-Ring 26
54329 Konz-Roscheid
