Approach for Building a bundle installer
I have installers for several apps, and we'd like to build a bundle installer that will install multiple apps based on users' selection. Here is what I planned to do, I would like to get any feedback to the approach that I am using.
1) create a new bundle installer project (using basic installer template)
2) each of the individual app will be a feature in the bundle installer
3) bundle installer installs the setup file for the individual app to MYTEMPDIR
4) for each selected feature, bundle installer invokes the individual installer in MYTEMPDIR in silent mode
5) remove the temporary individual installers from MYTEMPDIR
6) remove the registry entry for the bundle installer (so that it does not appear in the Add/Remove Program list), since it is not desirable to allow users to uninstall the whole bundle (they can still uninstall each individual feature one-by-one).
For CD distribution, it seems that it is not necessary to install the setup files to a temporary directory, since they can be included in the CD and the bundle installer can just invoke the individual installer from the CD. But the bundle installer is needed for both CD distribution and Web distribution, I am not sure that my approach would work well for CD distribution. Do I need to create another project just for CD distribution?
Thanks for any feedback and suggestion.
Regards,
Kevin
Regards,
Kevin
Re: Approach for Building a bundle installer
There's a few things to consider here.
Your options are basically:
Create a single (web-based) installer for both web and CD distributions.
Create a web-based installer for web distro and an uncompressed installer for CD distro.
Create a web-based installer for web distro and a custom uncompressed installer for CD distro.
I don't think the first option is the best idea (it will be pretty slow running off the CD).
I think your best bet will be the second option (of copying the installers to a temp directory on the hard drive) with a slight performance improvement over installing straight off of the CD (since the installers will probably need to decompress and this could take longer to go from CD to HDD than it would if they were already on the HDD and decompressed there).
What about this:
2) each of the individual app will be a check box in the bundle installer
3) bundle installer copies the setup file for the individual app to MYTEMPDIR
4) for each selected setup, bundle installer invokes the individual installer in MYTEMPDIR in silent mode
6) avoid apply install command then you have not to delete the reg key
Thanks for the suggestion. I have a question about the step 6). Is it possible to avoid APPLY INSTALL command? I thought that in step 3) we'll have to install the individual setup file to MYTEMPDIR. My understanding is that those pink INSTALL command are not run until APPLY INSTALL command is called.
No (speaking from experience from one who already has a bundled installer): You will call your installers using either the MSI plugin or the Run Program (msiexec etc).
Just remove the apply install in your MAIN mpr file at the bottom.
It is the TEAL color commands that will not execute without an apply install - such as writing a registry key - but I don't do that with my bundled installer so it works just fine.
=-Chris
=-Chris
Thanks for the reply.
I tried commenting out the APPLY INSTALL from my bundle installer, it stopped working because the setup exe files for the individual products are not installed to MYTEMPDIR.
I am wondering how do you copy or install the msiexec files to the target machine without calling APPLY INSTALL? Maybe, you are not using INSTALL command to copy/install them?
Ah, I see what you are doing.
Are you using file bags for your sub instllations? (I do - as they are defined as web media blocks). In any case, you need to use the variable that the files are unpacked at.
Let's look at an example - in your setup script for this particular component (to make life sweet - be sure you have a script block for each sub installation):
Now, later in the script block for my setup I do this:
(I happen to use Run Program)
(Don't write to the root of the C: drive - you should use %temp%MyFile.log (bad coder bad coder!
Then my call to Run Program:
I hope this helps you out.
=-Chris
Define File Bag : #IADIR#\runtimes\Clients\*.*, get runtime location of files into variable CLIENTFILES
Set Variable CMDEXECUTION to /i "$CLIENTFILES$Clients.msi" $TRANSFORMSWITCH$ /log c:\ClientInstall.log
Run Program msiexec.exe $CMDEXECUTION$ (WAIT, get result into variable CLIENTINSTALL)
=-Chris
Thank you for your reply and example. Now it makes sense to me. I am an IA newbie, this is the first time that I heard of File Bag. I'll try the technique in my bundle installer.
Thanks again,
Kevin
Thanks again,
Kevin
I mean you should not install the bundeled packages but just copy it by using kernel32.copyfile function by calling the kernel32.dll (copy your setups from $SUPPORTDIR$<your setup> to <yourtempdir>, add the setups to creatives before
). And afterwards call kernel32.deletefile to remove the setups from tempdir. Then use run program and start your installer. So you have no purple commands and you don't need ApplyInstall.
BTW we use a delphi application as frame for installation of more setups, so it is just my theory.
In this case, why bother to copy them from $SUPPORTDIR$ to target temp dir? Why not just invoke the setup files directly (Run Program $SUPPORTDIR$<myApp_setup.exe>) ?
$SUPPORTDIR$ wouldn't be a bad idea. It should appear on the hard drive, in a temp directory, even if you're installing from a CD.
Yes of course, it would be easier, I was caught in your example a bit.Why not just invoke the setup files directly
