Edit ini file during update
Raubi
Post by Raubi »
is it possible to update an ini file during an update?
I use the normal updates.mia which is provided by IA. Just did a few changes.
With this code I want to update the ini:
[DEFINE REGION: Download and Install Updates]
label: Check for Updates
Set Variable UPDATE_GET_INI to
Download File #UPDATE_SERVER# into $SUPPORTDIR$\updates.ini (get result into variable UPDATE_GET_INI)
Edit INI File $MYAPPDATA$\SoftwareName\Ro.ini, [Update] LastUpdateCheck=$DATE$
Apply Install
If I try it this way, I get the message:
SoftwareName
Error
The given path $MYAPPDATA$\SoftwareName is not available.
OK
I want to update the ini file even if the user decided not to install new updates.
Is it possible within built in functions or do I have to write a plugin for it?
Thanks for help
Re: Edit ini file during update
Post by mills »
What is $MYAPPDATA$ pointing to?
Raubi
Post by Raubi »
i found the problem. MYAPPDATA was not defined in updater context. But with the "Apply Install" the installer does more than just updating the ini file. So I wrote a little plugin doing the job.
