I need the algorithm of Serial Number Generator provided as an example with InstallAware package. I want to generate the serial on server side with PHP from customer name and company and after that to email the generated serial to the customer. Please help.
Re: Serial Number Generator
In the Serial Number Validator sample, the included script, Serial Number Generator has all the logic laid out for you.
mills wrote:In the Serial Number Validator sample, the included script, Serial Number Generator has all the logic laid out for you.
Yes i have checked that script file but unfortunately i can't replicate in PHP this 2 lines:
Set Random Number Generator Constants = 24337, 17312
Set Random Number Generator Seed = 31415
if someone have done this before maybe will give me some ideas ?
It's not clear what the constants are used for. I'm going to look at the code to see if I can find out what it does.
The seed should be pretty straight forward.
For PHP, you'll probably want to use srand() or mt_srand()
How about creating a single-executable using the sample to generate the serials for you?
You can have it write the serial to file and call it using PHP's exec()...
Thanks for your responses. I solved this problem
i have written my own key generator and validator to be able to integrate with the serverside key generator
iamfromk wrote:Thanks for your responses. I solved this problemi have written my own key generator and validator to be able to integrate with the serverside key generator
There is a way to share you app?
Or does anyone know from where to download ?
Users browsing this forum: No registered users and 15 guests
