executing msi with /passive option
figo
Post by figo »
I am unable to launch my MSI utilizing the /passive option successfully and I was wondering if all options available from msiexec are supported out-of-the-box for any generated MSI and/or are there any special code handling techniques that are required for each?
I created a IA sample program (user feedback and registration) and I was unable to get it to execute with the "/passive" expected results explained by the msiexec /?
/passive - Runs the Setup program or the removal program in "passive" mode. The program does not prompt the user with any error messages. The user sees a progress bar that indicates that the installation or the removal is occurring. The user cannot cancel the installation or the removal. By default, the program invokes the
Am I missing something? Has anyone tried this option with successful results?
If all else fails, Improvise!
http://www.luiscasillas.com
Re: executing msi with /passive option
Post by mills »
I've heard of mixed results using the msiexec /passive option.
My one question is the necessity of the msi to be used in this case? That is, if the iA exe provided a /passive option, would that be satisfactory, or are you depending on msi deployment?
