How to add a custom template project?
I would like to create a custom template project to be added to the list of available templates that appares when a new project is started. How to do?
I can not believe that it is not possible!
Re: How to add a custom template project?
Post by mills »
Have you tried adding a project to:
install_path\InstallAware\InstallAware 9 R2\Templates
Yes, I have!
I have added my template project to folder:
"C:\Program Files (x86)\InstallAware\InstallAware 9 R2\Templates" ..... but my template project it is not visible in the list of the available template, when I try to create a new project.
have I missed something else to do?
FrancescoT wrote:Yes, I have!
Any suggestions???
Post by mills »
I have verified that at the time, it is not possible to add your own custom template projects, but it is something we would like to implement.
Thanks for the answer,
I really hope the this feature will be added in next realease of IA. I can't belive that nobody else have asked for this. IT IS SO IMPORTANT!!!
regards.
