Seems that Dr. Web antivirus detects a tojan in one of the installAware files.
when i tried to download and install My Setup I got a popup alert regarding trojan in FirewallEXEPlugIn.dll
is there anything that can be done from your side?
Erez
Re: FirewallEXEPlugIn.dll
It sounds like you're talking about the plugin from Axonet:
http://www.axonet.de/eng/Axo/plugins_fo ... laware.htm
If so, you'll do best to inform them of this.
Alternatively, there may be a way to set an exception on the DLL in your AntiVirus settings so it won't warn you about it again. You'll have to consult that documentation or the vendor.
