Select Target Folder buggy?
alibaba
Post by alibaba »
The 'Change' button on the dialog 'destination' calls the built-in function 'Select Target Folder'.
The strange thing is that I have 3 different effects of this function:
1. (english Win XP): If I click on it and then create a new folder in the browse dialog and select this folder, IA always adds the $COMPANY$\$TITLE$ as subfolder.
2. (german Win7, same on a german XP in VirtualBox): the same behaviour as above but after returning from browse dialog the subfolder $TITLE$ is added. (the variables are always dissolved)
3. (german XP): The function works as expected, no folders are added.
So I have three different behaviours and I have no clue why...
Another strange thing is if I select the root system partition or the program files folder the path is set to default InstallDir (<system partition>\programfiles\<company>\<title>) if I remove from browse dialog. This happens on all the systems.
It makes no difference if I change the language of the setup, the behaviour seems to depend on the system.
Can somebody explain this or made the same experience?
Re: Select Target Folder buggy?
Post by mills »
According to the help, it should behave like:
TARGETDIR: Initial value set to <Program Files Directory>\Application Title, using the name of the product being installed as the application title.
I'm noticing on XP, if I choose C:\ or "C:\Program Files" from the dialog as the target path, it's relocating to C:\Program Files\$TITLE$\, otherwise it point to <path>\$TITLE$.
I'm not seeing a difference between XP and Win7. What SP of XP is running?
I'm also seeing the same behavior in a pure German XP, a German-lang pack Vista, also.
Might you be running an old version of IA?
From what I gather from your post, you just want the pure path... You'll probably want to use the "select custom folder" action on the button. See this post for details:
http://forums.installaware.com/viewtopi ... wse+button
