hello,
i am new to install aware .i have downloaded the trail version from website but i dont understand where to start.
how to install my software with sqlserver express and attach database.
plz give me step by step guidence how to do it with installaware.
with vs i use installer class to this .how can i do this with install aware
thanks
how to install sqlserver 2005 and attach database
shuaibwasifkhan
Re: how to install sqlserver 2005 and attach database
It will be easiest to add it as a runtime (in the Design view). Once you check it off, you can edit the options by clicking the Options button at the bottom of the list. You can view the generated scripts when you include the runtime in the MSIcode view.
