IA 9: Dynamically loaded images
pfennig
Post by pfennig »
Is it possible to dynamically load images into dialogs?
Re: IA 9: Dynamically loaded images
Post by mills »
The best trick for this would be to use an html control, pointing to an html file with the image you want to display. You can use the META tag to act as a "timer' to cycle through html pages (images) or you can rename the various html files to index.htm before calling a dialog with an html viewer (the viewer will direct to index.htm by default.
