.Net framework detection.
bokkie
Post by bokkie »
The .Net Framework plugin allows you to detect upto version 2. Is there any simple way of detecting the presence of 3.5 or 4.0 without having to drill into the registry?
Re: .Net framework detection.
Post by mills »
No, you can add .Net runtimes and examine the included check_runtime scripts that get included for ideas.
