TITLE variable and translation mtx file
benjoTLV
Post by benjoTLV »
I have a problem that I don't know how to solve...
it seems that in order for translation to work, the product name and the mtx files must be the same... my problem is that I define the project name by compiler variables and for each of my customers, the installer has a different name. Also, the TITLE needs to be different because if not, 2 of my installers on the same computer will present the same entry in add and remove program...
Is it possible to "tell" to the installer which mtx to use and is it possible to have different names for the mtx and the project??
Re: TITLE variable and translation mtx file
Post by mills »
Take a look at the help file for "Transform Instance"
benjoTLV
Post by benjoTLV »
Thanks, solved.
]I've just used the compiler variables and runtime variables correctly this time and it worked! sorry for the stupid question...!!
