finish Dialogs "Run now" does not work..
kyung jun lee
Post by kyung jun lee »
"C:\Program Files\KJBible2\KJBible2.exe" is the location of the file.
MSIcode, Use the instructions below, but does not work.
Run Program $PROGRAMFILES$\$TARGETDIR$\KJBible2.exe
Run Program $PROGRAMFILES$\$TARGETDIR$\\KJBible2.exe
Run Program $PROGRAMFILES$\\$TARGETDIR$\\KJBible2.exe
Run Program $PROGRAMFILES$\\KJBible2.exe
Run Program $TARGETDIR$\\KJBible2.exe
Run Program $PROGRAMFILES$\\KJBible2\\KJBible2.exe
Run Program c:\\programs files\\KJBible2\\KJBible2.exe
How do I give instructions?
Re: finish Dialogs "Run now" does not work..
Post by mills »
Run Program $TARGETDIR$\\KJBible2.exe should work.
What do you get as a result from the Run Program? You can display it in a messagebox.
