Is there a way to create Webmedia - Setups to use with a
different Main-Setup?
Howto Create Web-Media
Re: Howto Create Web-Media
Yes, Web Media Blocks may be shared by different setups as long as they contain the same (super)set of files needed by each setup and the source paths (not the target paths) are the same.
