New Features:
o Export projects to InstallAware Virtualization, available in all editions
o Crystal Reports Runtime Engine for .NET Framework 4 Application Runtimes (x86 and x64)
o $SETUPPATH$ pre-defined variable in the setup engine
o GlowLabel dialog control for Aero Glass
Bug Fixes:
o Download timeout regressions fixed
o Hybrid Installations may now perform uninstallations of the Native Engine and Windows Installer parts in any order
o Variable self-assignments no longer freeze the setup at runtime; they set the variable to an empty value instead
o Web Media Blocks located on the Group Policy MSI path will now be automatically picked up at installation time
o Assembly metadata is now read directly instead of running external programs
Also Updated:
o Memo dialog control now automatically displays scroll-bars on an as-needed basis
o .NET Framework setup template updated to use .NET Framework 4
o Help updates
When upgrading, be sure to install the latest trial version and then regenerate and reinstall your license as well. Back up all downloaded files for future use. When using the web installer, be sure to do a complete install and choose to save all downloaded files in the setup wizard in a safe location.
Remember: Keep a safe copy of all the trial installation files and the license file. Your license file and trial install must always be the same version!
