IIS Virutal Directory Problem
nbmkumar
Postby nbmkumar » Wed Feb 08, 2006 9:04 pm
We are evaluvating installware for creating setup file for IIS web application.
When I try to create a virtual directory, it is not creating any virutal directory in the IIS. it doesnt show any error too. Do you have a tutorial or help on creating the IIS Virtual Directory(Step by step both in visual and code mode). i dont want to create a new website from the setup program. i want to create a virutal directory in the existing web site.
My Code.
Create Virtual Folder "/ictm" in IIS Site #1, pointing to physical location $TARGETDIR$
Muthukumaran
Postby MichaelNesmith » Wed Feb 08, 2006 9:20 pm
Are you executing the command after Apply Install?
If you create a new project based on the Win32 template then use the visual views to create your IIS site, it will work fine.
sinan
Postby sinan » Thu Feb 09, 2006 9:18 am
Kumar
Do not post the same question multiple times. I have deleted your extra posts. If you want to revise an existing post, click the Edit button instead.
Your post has also been replied to by Michael.
Thank you,
Sinan
Users browsing this forum: Bing [Bot] and 86 guests
