Change Log for InstallAware 10.0.3
sinan
Post by sinan »
This release fixes the uxtheme.dll and other random access violations that occurred with the first patch onwards. We have been working on building the first Aero Glass Wizard themed installer, and trying to do it the InstallAware way (where you'll be able to customize everything in your dialogs - including the glass regions). Unfortunately some non-production quality code slipped in through the cracks during this process. Because the issue does not consistently manifest (especially in automated testing), our QA did not spot the problem before the release. Unfortunately, potentially all InstallAware binaries are affected by this issue, so the only recourse is to reinstall the full package.
We're very sorry for the hassle, but those of you who upgraded to version 10.0.1 will need to upgrade again to 10.0.3, potentially downloading the full package again. Please remember to regenerate and reinstall your licenses. Please back up all downloaded licenses and trial installs safely for future re-use. If you will use the web based installer, please make sure you choose the "Full" setup option, and then choose to "Backup Downloaded Files" and keep them all safely stored.
There is one more enhancement in this release in addition to the bug fix. InstallAware and compiled setups now run a lot more smoothly on multi core systems, using less CPU and less power at the same time. We improved our task scheduler and we hope you like the results.
Thank you for choosing InstallAware, and we hope the timely update helps offset part of your inconvenience!
